Setting thermostat in the house I am able to feel air blowing, but the condensing unit outside is not working (fan not spinning - not "on"). I pulled fuses out and tested them - they are working - continuity. Installed 2005.
This will be a new adventure for me - (have totally pulled apart dishwashers and microwaves and ovens and a little work on furnace -- no a/c experience yet)
What should I look for next? For some reason I am a little intimidated at this one -- even though it looks pretty straight forward..Thanks in advance for the troubleshooting.:eek:
While I was waiting for anyone's input, I continue to investigate the issues. As I said, air was being blown out of the vents. Fuses working, but no sounds coming from the condensing unit outside. I tested the contactor and it did appear to have a "bug" in the contact. I replaced that and when I flipped power back on - I got that distinct humming sound - but no fan spinning. Which leads me to the capacitor. I don't know why I didn't do a visual check on this at an earlier time; but it is a little domed on top and I can now verify that there is power - so I ordered a new capacitor. Unless there is something additionally wrong with the fan motor as well, I think this will solve the issue. Will continue to update. So far only into this for about $35 for both parts and time...
Boom Fixed! New capacitor also installed. Cold air. contactor and capacitor replaced both for under $40.
Originally Posted by: CarolynE  Setting thermostat in the house I am able to feel air blowing, but the condensing unit outside is not working (fan not spinning - not "on"). I pulled fuses out and tested them - they are working - continuity. Installed 2005.
What should I look for next? For some reason I am a little intimidated at this one -- even though it looks pretty straight forward..Thanks in advance for the troubleshooting.:eek: I think you should consult with an HVAC contractor in your nearby location
The same problem happened with me when I was in Dubai. Then I contacted ac maintenance in Dubai. Then they solved my problem.
