Groups ready for retrieval: Registered
An item of clothing is often getting stuck at the same point in the top left of the drum. A repair guy said it looked like there used to be a foam strip around the top of the dryer front drum bearing. He said he tried to order it but it is no longer made, so nothing can be done. However, I don't see any foam strip showing on the parts diagram on the top of the bearing. https://www.geapplianceparts.com...0/FRONT_PANEL_&_DOOR I only see part #312 - (GE WE9M15) -- the dryer duct felt trap. This goes round the bottom and side of the bearing, not the top, and it doesn't cross the pinch point. I replaced this part in case it was the problem, but has not fixed it. I'm thinking the next step is to replace the glides?
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
