kenbo22
#1 Posted : Tuesday, June 26, 2018 11:54:43 AM(UTC)
kenbo22
The ice maker in my Frigidaire Gallery has stopped producing ice. I checked to make sure the water line entering the ice maker was not frozen. There were frozen cubes in the ejector but the ejector will not turn. I melted the cubes to see if that mechanism was frozen or "stuck" but the ejectors still will not turn but I am also not sure if that mechanism should turn manually anyway. I am pretty good with DIY but have never worked on a freezer or fridge so just need a little help diagnosing the problem. Regards, ken
ThatGuy
#2 Posted : Thursday, June 28, 2018 7:27:35 PM(UTC)
ThatGuy
Groups: Expert
United States
I would check part 11. check it for continuity. Its a thermal fuse.
Parts for Frigidaire LGHS2634KP0: Ice Maker Parts - AppliancePartsPros.com
