pjineson
#1 Posted : Tuesday, June 26, 2018 6:44:33 AM(UTC)
pjineson
I have a Propane dryer that the timer does not move when set. It also does not work on automatic dry but will work on time dry high heat. When set to low heat it does not dry. Thoughts? Is it just the timer or something else?
ThatGuy
#2 Posted : Wednesday, June 27, 2018 3:28:10 PM(UTC)
ThatGuy
Groups: Expert
United States
It could be the timer or it could be this part.
Whirlpool WP3387134 Dryer Cycling Thermostat - AppliancePartsPros.com
It kind of sounds like the timer, but testing the other part is easy.
