bjornolf
#1 Posted : Thursday, June 21, 2018 8:13:14 AM(UTC)
bjornolf
Hi, need some help here. So, about a week ago, my icemaker filler line on my kitchenaid KSRG25FVMS05 refrigerator didn’t stop and flooded the freezer with water. If I turn the icemaker switch off and on again, it stops. Then it works properly. However, about every 24 hours, it does it again. I did some research and decided I needed a new water inlet valve. So I ordered one off Amazon that said it worked for my fridge. I installed it fine. However, now there is a leak right where the water supply line goes into the water inlet valve. So, to check, I took the new on off and put the old one back on. Now the old one is leaking too, same spot. Which it wasn’t doing before! What am I doing wrong here?
Thanks,
Joe
