My Kenmore gas convection oven takes forever to preheat. Today I accessed the burner and noticed that the igniter doesn’t go off. It’s like there is not enough gas or not enough gas pressure to get the burner hot enough to disengage the igniter. All other functions are working perfectly including broiling. The self clean, however, does not get hot enough to clean. I’m guessing because the bottom oven burner doesn’t get hot enough. Is there an orifice where the gas goes into the burner that could need cleaned/replaced? Or maybe electrical issue? Thanks
