The icemaker seems to make ice intermittently, but even after it makes ice the ice melts in the ice tub in the door. At first I though the flap to the dispenser might not be closing properly, letting warm air in, but that is not the case. Does not seem to make ice consistently - maybe will for a couple days (the ice melts then it stops making ice for a couple days. Had a repair guy here and he couldn't figure it out either and wanted to just start throwing parts at it. May be the seal between the ice bin and the icemaker (when door is closed), may be the mullion that holds the doors tight, may be the ice maker itself..... Just looking for thoughts on what to try first. Thanks
