Tailhunter
#1 Posted : Saturday, May 12, 2018 7:59:53 AM(UTC)
Tailhunter
I have an LG washing machine that wont drain. If I lay the drain hose down the water comes out just fine so I know it is not clogged. When I put the washer on spin the pump tuns on for 1 second and spits out a little water then wont turn on again. I took the pump off and plugged it into the wall and it ran just fine. When I put it back in the washer it will run for 1 second and then wont run anymore
LG washer wont drain (Washer Repair)
by Sunshine56 11/14/2012 6:36:13 AM(UTC)
by hondakubota 8/3/2011 3:58:00 PM(UTC)
My LG washer wont drain (Washer Repair)
by punks1977 11/9/2008 11:08:16 AM(UTC)
