hiltzja
#1 Posted : Monday, May 7, 2018 7:18:42 PM(UTC)
hiltzja
Hello, our Samsung me18h704sfs microwave is not working. The display is completely dead, except for when you close the door. The display flashes "12:00" for a split second as soon as the door is closed, then goes blank again. The power can also be restored by tapping (or beating) on the microwave. It has stayed on long enough to run a few times, but it usually goes blank again within a few seconds of it turning back on. Has anyone seen this issue before? Could it be as simple as a loose electrical connection internally?
