Tried to start it and no keypad LEDs would come on. After about 30 secs selected LEDs turned on but I had been pressing all of them before. I closed the door and it started based on the previously programmed settings. I left the door open all day as i was paranoid it might startup on its own. Tonight I shut off the breaker for over 1 minute and turned it back on. Then closed the door and it did not start as I expected because I didn't want it to start. Load it up again and press Start/Cancel. I get Start, Sanitize and Normal to light up. No other keypads responding. Ii shut the door and it starts washing.
I think I have a faulty touchpad. Does the touchpad panel lift off and are there leads on each switch I could check for continuity?
Thank you in advance.
