benjaminfoj
#1 Posted : Tuesday, April 17, 2018 8:19:21 AM(UTC)
benjaminfoj
After trouble shooting range for run away oven, replaced oven control board.
Oven working great. Range showing F5-00 in burner windows (both sides)
I have unplugged range and rebooted several times. after rebooting the range will operate fine for approx. one minute. Then starts beeping.Turning on the inside burner (either side) turns off the beeping. Burners work beautifully but does not display power setting to burner. immediately after turning on inside burner, left to right, display reads, F5-00................F5-00 in burner display window. Any suggestions??
