My fridge was diagnosed that it needed a new compressor & refrigerator icing repair kit. I kept using the fridge for about 6 weeks at which time the freezer temp went to 40 degrees & the fridge to 50. I turned off the circuit breaker & emptied and cleaned the entire refrigerator. A few hours later I noticed a small amount of watery brown liquid at the bottom of the freezer. I cleaned it all up and again many hours later the watery brown liquid showed up again. I attached a picture to show the liquid at the bottom of the freezer. Any ideas as to what the issue is? dmoliver attached the following image(s):
