My dryer just stopped staying on. It wasn’t overheating or not drying. It just stopped staying on. I would push the start button it would run for about 15 seconds and shut off. I ran diagnostics and the code F 25 code came up. I replaced the thermal fuse, the thermistor, the heating coil elements (which the metal behind the coils was charred and starting to crack) and the thermostat cutoff system. Went to start it up again and it did the same thing, shut off immediately. This time I put it on the timed dry setting (which I never use). The dryer turned off almost immediately but then the timer kept going and less than 3 minutes later dryer turn on by itself. I’m at a loss as what it problem is. Any help and information would be greatly appreciated.
I replaced both of those parts too. (inlet thermostat & wiring harness)
I replaced the control panel board in January. I will take it out along with the other board and double check it. I'm so frustrated~ Having spent $200 on this dryer in January and now $125 in the last week. I just want to through it into a dark hole. I'm on the edge of just buying a new dryer, but I hate that I can't figure out what is wrong with this one. Thank you!
