1alembic
#1 Posted : Wednesday, April 4, 2018 5:59:05 PM(UTC)
1alembic
Hi, I have a GE gas oven/stovetop (Mod # JGBP28SEJ1SS). The stove top burners ignite and create a flame fine. It also seems that the oven heats up when set to Broil. However, when the oven is set to Bake it does not heat up.
Based on some of the other threads I have read it sounds like I might need to replace the igniter. Would someone mind providing any thought on if the igniter is the issue and/or if there is something else I should be considering?
If it is the only the igniter I assume I need part #AP2014008
Thanks.
1alembic attached the following image(s):
1alembic
#2 Posted : Thursday, April 12, 2018 5:43:29 PM(UTC)
1alembic
Hi. I'm still hoping for some thoughtful feedback. Thanks.
ThatGuy
#3 Posted : Friday, April 13, 2018 2:09:51 AM(UTC)
ThatGuy
Groups: Expert
United States
It sounds like an igniter. Can you see a glow from the oven igniter?
If not, does it have 120 volts to it?
Its also possible to have a weak igniter that will glow, but night light.
part
GE WB2X9154 Round Style Oven or Broiler Igniter - AppliancePartsPros.com
Guest (4)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
