User Interface is stuck - shows a #1 in the display and the Sani Rinse light stays lit. I have turned off power and will not reset. ran D/W through a normal cycle and seemed to work fine, but nothing resets. Any tips? Should I look at the U.I. first or look at the Electric Controller. thanks
