AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer Stops and Restarts or Just Stops All Together
The dryer will usually run on full load well and then start acting up from there. This is not always the case however.
As the title states, the dryer will often start and then stop and automatically restart. Sometimes there is a significant amount of time to restarting, others it happens right after shutting down. I have noticed a number 4 on the display when it first shuts down.
Also, on timed dry it will automatically shut off even though the clothes are slightly damp. It will heat up and run for about 45 seconds and then shut off again. The dryer is clear of lint and I have replaced the following parts:
High-Limit Thermostat Thermistor Thermal Fuse
The dryer runs great otherwise and since changing these parts I can feel a temperature difference when choosing Regular, Perm Press, Knits, etc.
Thank you in advance!
Dryer Repair
