The bake element on my wall oven will not hear up. The element measures 18.6 ohms resistance. There is power to both leads that are attached to the element. Reads 123V at each lead
Groups: Expert
Across the element terminals you should read 240 VAC. If you are only reading 120, then half your voltage is missing.
