Frigidaire Gallery top gas oven quit working about a year ago but the broiler still works. The bottom oven quit working yesterday. When I turn either oven on the panel stays on 100 degrees but nothing happens. I removed the bottom plate and there is nothing. All 4 stovetop burners work fine .
Groups: Expert
If you don't see any glowing its probably a burnt out ignitor.
I need a model number so we can see what kind of parts are inside.
Groups: Expert
Thank you so much. Is the part the same for the upper and lower oven?
Also, is there an "off brand" part that us not quite as expensive since I'm having to buy 2?
Groups: Expert
