I have a Frigidaire refrigerator model FFSS2314QS. When entering this number into AppliancePartsPro, about 6 similar model numbers comes up, none of which is FFSS2314QS (Example: FFSS2314QE2A). Does my model number not exist at AppliancePartsPro, or is my model number the same as one of the 6 alternate model numbers? If so, which model number should I use? Thank You, Susan Susan899 attached the following image(s):
Groups: Expert
The extra 1 or 2 digits at the end pf your model number are revision numbers. 0 is probably the base model and all the other ones have had changes made to them. Different controls or colors or ?
What part are you needing?
