Wild Whiskers
#1 Posted : Wednesday, February 21, 2018 6:37:59 AM(UTC)
Wild Whiskers
I had a bearing failure on the inner drum .Replaced the bearings and seal .Also replaced the boot with new since i had it apart .I watched the videos from 2 places and I am fairly sure it can not fit any differently . The replacement uses the door side spring instead of glued . In the spin cycle the upper area of the boot is contacting the rotating inner drum enough that as it gets dry it begins to squall . Any suggestions as to what might be wrong Thanks
