amgropl
#1 Posted : Tuesday, February 6, 2018 9:30:16 AM(UTC)
amgropl
My Maytag Maxima Washer (Model #: MHW6000XW2) had the E01 F01 error.
I ordered (from AppliancePartsPros.com) and replaced the Electronic control board ([FONT=&quot]W10427972)[/FONT]. The Error is gone, but now, every time it reaches “Sensing” the machine gets stuck. It will not move past that step.
It does not matter how I get to that step, Big load, small load, rinse and spin or even in Quick Diagnostic Test it gets stuck at C06 and I need to abort without results.
Water fills (hot or cold), drain pump is working, I cleaned out the drain strainer.
