The dishwasher isn't cleaning well and dishes are wet. This is with using Sani, steam and heated dry. Ran diags and everything passes. I measured the heating element during diag at around 126 degrees. When running cycles there just isn't any hot water. I always run hot water to faucet it's connected to before running also.
Any ideas? Thanks!
