tpoynton
#1 Posted : Thursday, January 25, 2018 3:59:28 PM(UTC)
tpoynton
Thanks in advance!
Washer not entering high speed spin, has code e41.
I have tested resistance of wax motor, 1380, and checked to see if drain was plugged, both check out. Checked j2 black wire again other wire in plug and circuit was open. Striker looks fine, and door locks and I can not open. Everything seems to point to door latch, but I wanted to check before buying. I I
Opened up the latch assembly and a little spring was floating around in there, and I found a video showing where it went and put it back in place, but I still get the error. Ran through diagnostic cycle too, and high speed spin works there. Would you agree that the door latch is most likely culprit, and it is not as likely to be control board? Thanks again!
tpoynton
#2 Posted : Sunday, January 28, 2018 4:51:21 PM(UTC)
tpoynton
An update, replaced door lock mechanism, worked for a few loads, but now it is back with e41
tpoynton
#3 Posted : Friday, February 2, 2018 12:13:17 PM(UTC)
tpoynton
Final update on this...appreciate all the input :)
the error comes back when there is a very small load in the washer, so it is probably something else and I now have an extra door latch assembly. Can either not do small loads or just spin it out in diagnostic mode.
Guest (4)
