jim.walters
#1 Posted : 7 years ago
jim.walters
Double oven. Lower oven works fine. Upper oven overheats past setting on convection and non-convection modes.
I swapped the temperature sensors which did not resolve the upper oven overheating issue.
Any guidance appreciated.
ThatGuy
#2 Posted : 7 years ago
ThatGuy
Groups: Expert
United States
It sounds like a stuck relay. You might be able to replace the bad relay, if you are good at soldering. I cant be sure, but its probably one of the six larger ones on the lower left side of this picture .
UserPostedImage
