A couple of weeks ago, the oven started acting up. It would not build temperature, and you could hear a relay clicking on and off in a rapid succession. I power cycled the oven (shut it off for a few minutes and turned it back on - at the breaker), and it started to work again.
Fast-forward to tonight, we started the oven, and it wouldn't shut down. Tried turning the oven off with the temperature control, and it wouldn't shut down. Finally had to turn the oven off at the breaker to get it to shut down.
The element itself doesn't appear to be damaged. No spots, no blisters.
I'm leaning to there being a problem with this relay.
Any help?
