bropete
#1 Posted : Friday, December 15, 2017 5:48:57 PM(UTC)
bropete
Drain motor runs constantly, door locked, etc. Unplugged, waited, plugged back in - still running but now no error #'s - screen is blank. Removed water level pressure switch and it fell to bottom of cabinet. Finally got it, removed and blew through the hose from water level pressure switch - its all clear. Removed same hose, etc. from bottom of machine - all clear. Reconnected everything and turned it back on - same problem. Did the diaphragms in the pressure switch get messed up when it fell? Or is it another problem? What should I do now? Thanks!
