i ordered the tco oven cavity and Thermistor to try to fix a blank display. Is this the right diagnosis. All oven functions are working fine. just the display is blank.
Other internet search points to tco oven cavity (wb21x10046) and or thermistor (wb27x10468) replacement as the fix.
Thanks in advance
I cannot find a wiring diagram for this unit so am guessing that since all functions work it is the display board that is a shot.
Or if the display is part of the control board, it is shot. |
THIS FORUM IS DEAD!!!!!!! |
