I ohmed out the bake and the broil elements they are fine. I really dont know how to ohm out the switch that operates them but I tried and I did get ohms in certain parts of the switch. What else could be wrong.
If there is nothing wrong with the heating elements and wiring harness then the problem is a bad control (#6 on the diagram). - The oven control switch Part number: AP3885365
