Trying to replace a broken door handle of PVM9179SF1SS microwave / convection oven. i am able to take the choke out but the door handle screws are underneath another metal frame. i tried unscrewing the 3 screws on the metal frame but was not able to pry it out. please advise
You probably would need to remove the whole door from the oven. Then you would need to remove the inner door frame to get access to the door handle screws. Be careful because most of the parts for this door are no longer available.
