Just started making a grinding noise when draining. I pulled out the drain screen and popped off the lower arm but the unit appears to be all one plastic piece and I'm not sure how to get to the drain assembly. I'm assuming I may have to un-install the whole unit?
Sorry, I should add the model Ascenta- Black SHE3AR56UC
