My mother has a Maytag electric range. Model CRE9800CCE. The left front small 6" burner had burned out and I replaced it with a new burner. After repair turning range burner on it will only heat on high now. I assumed the infinite switch had also had a problem so it was then replaced with a new switch. Burner still heats only on high. I'm stumped.
