My electric range will not hold the temperature it is set at, it reads that the temperature is as set but when checked with internal thermometer it is 25-100 degrees less than it reads. When turned off then turned back on it will reheat to the set temp, but then loses heat again. It won’t retain the temperature!!Any ideas what the deal is! Wish me luck cooking a turkey tomorrow!
