Sandeep Viswam
#1 Posted : Tuesday, November 21, 2017 1:45:29 AM(UTC)
Sandeep Viswam
I have a Samsung top load washer WA80U3. Its spider arm is broken and I have tried to remove it. I am managed to remove agitator bur I cant remove the spider bolt. Should I require any special tool to remove it? It should be turned clockwise or counter clockwise to remove it? I have seen in some LG models the bolt should be turn clockwise to remove it.
Or should I follow any other procedure to replace the spider, other than these steps... remove top of the machine, and remove agitator and then inner tub... like remove something from the bottom? I have searched a lot on the web for last 3 days, but could not find any proper solution for samsung top load.
Kindly help. Please share if you have any video or step by step procedure to replace spider.
Regards,
Sandeep
