buck_dizzle
#1 Posted : 7 years ago
buck_dizzle
After heating up for about 5 mins my oven shuts off and flashes the error code F3E2. I have read lots of forums that indicate this is due to an overtemp issue. I tested the temperature sensor and it is normal at around 1100 ohms. I replaced the control board from ********************************.com and assumed that would fix my problems. However, the same issue seems to be happening. Any suggestions at this point? Or anyone have similar experiences?
ThatGuy
#2 Posted : 7 years ago
ThatGuy
Groups: Expert
United States
I'd try a new sensor. I've seen them fail in many different ways over the years. If you get it from here, you can send it back if its not the problem.
Whirlpool WPW10181986 Oven Sensor Assembly - AppliancePartsPros.com
