The oven just abruptly stops working. The light button on digital display does nothing as does the timer. Underneath the clock display are the letters SF. Any clues as to what's wrong?
Groups: Expert
I found this.......
"The "SF" appeared because you were in the Oven Calibration mode. You needed to press the Bake pad to enter oven calibration mode. 00 or a number between plus or minus 35 degrees will be displayed. Press Temp increase or decrease pads to change the average oven temperature. Press Start to return to the Time of Day"
