Hi Guys...I replaced my circulation pump yesterday in a washer that wasn't cleaning or dissolving the soap tablets. When I cut the power back on to it, all of the lights came on and stayed on. I looked around and saw some of the posts about the reset code, hi temp wash-heat dry-hi temp wash...i tried that and it seemed like it came on, all the lights stayed on but it went thru a whole wash cycle. I let it run thru to verify that the pump fixed my problem (it did) but now all the lights are still on and I can't recreate the sequence that got it started last night. Any thoughts on this? The buttons beep (sometimes) when I push them. I am thinking this is going to end up being an easy fix once I know whatever the secret code is. :cool:
I have been able to get it started a couple times with the heatdry-hi temp wash-heat dry hi temp wash..."reset" a couple times but i am still stumped for getting it to start normally. and it won't let me choose a cycle. every time i have gotten it to start it has just been me randomly pushing buttons. I could really use a tip on this one.
I have the same proble. Did you figure out a solution. Dishwasher is stuck in diagnostic mode. All lights ON.
