walkerapp
#1 Posted : Wednesday, October 11, 2017 2:49:53 PM(UTC)
walkerapp
Icemaker stopped working. removed icemaker found burnt heater terminal inside icemaker. Replaced icemaker then jumped the module to start it and nothing happened. So I removed the icemaker and tested for voltage at the plug and got zero volts. No tech sheet behind front grill. Part number for the tech sheet on ******************************** is W10544193. or is there a training guide available for the french door refrigerators? Any problem areas i should start at?
