Maytag Dryer will not start. I can hear the ticking/buzzing from the Cycle Knob when turned to a cycle, but will not start when pressing the Start Button.
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
A number of issues can prevent your dryer from starting. 1. Check to see if you have 240v coming into the dryer from the outlet using a multimeter. 2. Check the door switch for continuity when closed. A faulty door switch will prevent it from starting. 3. Check thermal fuse for continuity. It to will prevent the dryer from starting. Whirlpool WP3392519 Dryer Thermal Fuse - AppliancePartsPros.com After checking these items let us know the outcome.
