All of the sudden the "+" button (used to increase temp or minutes on the timer) stopped working. All of the other buttons are fine. The oven still heats properly (though I can't go higher than 350 because I can't use the up button).
I can't figure out which part I need to replace. I can't even figure out what the part is called. Can anyone help?
Thanks in advance.
P.S. If anyone happens to be able to find a link to where I can buy it, I need the white one.
Groups: Expert
It should be part no. 12001620.
Every where I looked it was NLA. But there are places that could repair your board.
