I have an issue with the icemaker on my fridge model RF4287HARS. Icemaker stopped worked. I replaced with new icemaker (DA97-07365G) and pushed reset. Unit cycled and filled with water. 1st load dumped into bucked then refilled but would not eject second load of ice into bucket. I pulled icemaker out and the rakes that sweep ice out of icemaker into bucket we frozen into the cubes that were in the mold. Though it seemed odd to me that it would eject 1st load of ice but no more, I figured it was a mold heater issue and got another icemaker (under warranty) since this one seemed defective and I got the exact same problem with 2nd icemaker. I ordered the main control board since it controls power to the Mold heater on icemaker. I replaced board, reset icemaker again and get same thing. I am at my wits end. $500 in parts on this junk fridge that still will not make ice. ANYONE have any ideas?
I had the same problem - started last year. The fridge was only a few months old so Samsung came out repeatedly to fix it.
First they replaced the water trough assembly. Then the main board. Then the heater for the water line, then the ice maker. Finally they replaced the freezer door. That seemed to fix the problem.
