I replaced the boot seal in the door because water was trickling out behind the base of the door and running down the lower front part of the washer. Still have the same problem. Clamps are installed properly and there are now wrinkles or issue with the boot seal itself. It's OE equipment. Any suggestions on next steps? Door is aligned properly and seems to be snug against the machine.
