Bartonappliance
#1 Posted : Friday, September 8, 2017 5:41:26 PM(UTC)
Bartonappliance
HELP!
LG Compressor model #: TCA35911902 for a Model #79574029411 KENMORE ELITE Bottom-Mount Refrigerator.
Just got in a new compressor and trying to install...but for some reason this is reading the same as the old....I can't imagine that it is actually a DUD as it is brand new....pray it's not.....
Someone out there able to tell me what voltage it should be showing? What resistance should it test to be??? Please...asap....working on it now and quite desperate...
PNWDrew
#2 Posted : Saturday, September 9, 2017 6:37:12 PM(UTC)
PNWDrew
This a variable speed linear compressor driven by an inverter board so forget all you know about the old style. Voltage will vary depending on what the main control thinks it needs. It'll peak about 200V I think. Amp draw is meaningless too. Freaking pain in the a@@ to diagnose unless it's noisy or other obvious issue.
There's a button on the main board, press it and it beeps; that'll put it in test mode 1 --full speed compressor. It'll take a few seconds to ramp up. You can test voltage at the board if you want to.
