jmden
#1 Posted : Wednesday, August 23, 2017 7:03:25 AM(UTC)
jmden
https://www.applianceblog.com/ma...yer-won-t-dry-GGW9200LQ0
Had same or similar issue above linked about 5 years ago. I put a couple of items in the machine that are moist, run it, and I don't hear the click of gas coming on, I don't see the igniter getting warm. Gas coils again, or...?
jmden
#2 Posted : Wednesday, August 23, 2017 7:26:11 AM(UTC)
jmden
...the readings fall into normal limits. What is the next thing to check?
PNWDrew
#3 Posted : Saturday, August 26, 2017 7:44:35 AM(UTC)
PNWDrew
Thermal fuse on blower housing. On gas dryers it interrupts the hot leading to valve assembly. Should be closed, 0ohm or close to it.
#59 on this drawing
Parts for Whirlpool GGW9200LQ0: Bulkhead Parts - AppliancePartsPros.com
