Troy217
#1 Posted : Sunday, August 20, 2017 8:34:58 AM(UTC)
Troy217
I have LG washer wave force. I heard it making a lot of noise in the spin cycle.
Googled it, learned it could be the Clutch/bearing. Replaced it. Thought it was fixed. NOT still made the noise. Saw that the balance ring was wearing on the plastic cover. The balance ring had holes in it. Replaced that. thought it was fixed. NOT. had to shave some of the plastic cover down so it would not rub on it. thought it was fixed. NOT. still rubs on spin cycle.
The rods and springs look good in it.
The tub and outer plastic tub looks fine and all moves as one unit.
Anyone have an idea on what to do next?
LG Washer 0E (OE) Error After Pump Motor Replaced (Solved) (Washer Repair)
by kilimar 6/3/2024 2:34:22 PM(UTC)
LG washer not letting in cold water (Washer Repair)
by Cgrigson1 4/19/2024 7:34:57 AM(UTC)
** LG Washer wont spin - LE Error ** WM4070HVA (Washer Repair)
by jborka 3/14/2024 6:15:24 PM(UTC)
LG Washer WM4270HVA/01 incomplete draining OE error (Washer Repair)
by PapawZooKeeper 6/18/2023 12:46:26 PM(UTC)
LG Washer - Rotor and Stator Grinding (Washer Repair)
by Guest 11/30/2022 7:57:29 PM(UTC)
wt7600hwa lg washer (Refrigerator & Freezer Repair)
by Guest 8/19/2022 7:47:52 AM(UTC)
LG Washer Error TE (Washer Repair)
by leonthepc 7/17/2022 1:34:39 PM(UTC)
WT5270CW LG Washer (Washer Repair)
by Gerald Shaffer 7/6/2022 12:59:29 PM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
LG washer -Drum not spinning during rinse cycle with Fe error code (Washer Repair)
by Guest 12/29/2021 3:31:30 AM(UTC)
LG washer WM2050CW has water in it after not running for a day (Washer Repair)
by hklein 12/16/2021 4:48:27 PM(UTC)
LG washer tromm (Oven Repair (including Ranges and Cooktops))
by Guest 6/18/2021 5:43:36 AM(UTC)
LG washer not powering on (Washer Repair)
by diyer2018 6/13/2021 6:29:13 PM(UTC)
lg washer power when tub is spun by hand (Washer Repair)
by robin2741 3/29/2021 10:56:54 AM(UTC)
LG Washer WT1101CW (Washer Repair)
by rsrosenberg54 3/15/2021 6:53:23 AM(UTC)
