suzchris
#1 Posted : Wednesday, August 9, 2017 2:58:19 PM(UTC)
suzchris
Ok.. this has been bugging us for months. It will only get part way through the cycle and then stall, and the clean light will blink its 7 blink message.
I have replaced (but kept the old one since it seems it was ok):
The heating element
The high Temperature cutout
The thermistor (thermostat)..
And the door handle. (ok, I know that wasn't it.. but hey it needed fixing).
Still... about every other time, or every third time, we get the fault.
I reset it.. and start it again, and it will always run through that time (although it runs for hours). Next time we use it, it will be fine..
Time after that.... fault.
Connections looked fine on the heating element. Everything looks clean and new. I also cleaned the pump/grinder area.. that was the first thing I did.
The only thing left to replace, I suppose, is the control board. But I am thinking if that was bad, it would never run.
HELP!
Thanks for any help.
Chris
suzchris
#2 Posted : Sunday, August 13, 2017 6:39:10 AM(UTC)
suzchris
Ok, in the thought that it isn't getting enough water, I have tried adding about a 1/2 gallon of hot water before I hit start. Well, it worked twice, and I thought I was onto something.. and then 3rd time. Blinking Clean..........
ugh
blinking clean light - what to check next (Dishwasher Repair)
by signal 9/21/2012 7:24:23 AM(UTC)
blinking clean light won't shut off (Dishwasher Repair)
by jackwolfe 8/5/2011 11:52:50 AM(UTC)
Blinking Clean Light (Oven Repair (including Ranges and Cooktops))
by CJ1959 11/16/2010 1:07:23 PM(UTC)
Kenmore DW blinking Clean light (Dishwasher Repair)
by Badabinbg 9/14/2009 6:51:48 AM(UTC)
Blinking Clean light after installing new control module (Dishwasher Repair)
by parrottf 5/30/2008 6:23:09 PM(UTC)
Kenmore Blinking Clean Light (Dishwasher Repair)
by caste 1/31/2008 9:14:37 AM(UTC)
