johnMis
#1 Posted : Tuesday, July 25, 2017 5:00:23 PM(UTC)
johnMis
Watching belt and motor from back - all looks good but when motor seems to switch the drum's direction I can hear a squeak, sometimes multiple attempts to change directions. I can spin the drum by hand an no bearing sounds - also leaks water - a bit but I think that is independent and maybe the boot. I note that sometimes in worst case scenarios, the washer stops when trying to change directions. Thank you for your thoughts
PNWDrew
#2 Posted : Thursday, July 27, 2017 9:31:52 PM(UTC)
PNWDrew
It may be the belt but it's probably the tub bearings. Ignore it until something more dramatic happens, the bearing job on that is $$$$, not worth it unless you love it.
