tako555
#1 Posted : 8 years ago
tako555
Recently my Vent Hood is noisy when I turned on the fan.
So I checked the kitchen aid web site and it says it probably caused by Motor
I did purchase.
https://www.kitchenaidparts.com/...oud-or-noisy-KWCU205HWH1
But the problem I face now is how to remove the fan.
There are so many screws and there is no manual describing how the cylinder shaped ventilation is attached to the hood.
I see the parts diagram but It does not tell me the proper way to disassemble.
Some screw cannot take out due to the too narrow space.
I took the photo inside my range food and I am not sure if I can simply unscrew the big (inside red in the picture)
What is the best way to try clean the parts and replace for this model inside fan (cylinder shape)
I looked at the Costco similar model but it seem to be much easier to disassemble this model make me headache.
tako555 attached the following image(s):
millyferry
#2 Posted : 7 years ago
millyferry
This is so helping I almost stuck at removing the fan and this kinda helpful.
tako555
#3 Posted : 7 years ago
tako555
Hi So were you able to unmount or you have the same range hood?
I have not even started (More than 4 month past)
So we cook without Ventilation now.
But I guess I have to start soon.
Thank you for your feedback
