The wife is having to run 2 drying cycles per load on anything but bulk cycle.Bulk cycle does fine.Dryer vent and filter is clean .Any suggestions on what to check.
The dryer vent blower is another area to check. It may be clogged or in some models is loose on the shaft thus not providing the proper air flow.. The dryer will have to be dismantled to check this area and/or clean it out.
