Hello,
My DW started occasionally not filling when I would press Start. Stopping it/resetting it would run through a drain cycle and then I could re-start the machine. Normally it would fill right away after that.
This week, it stopped filling, completely.
I bought a fill valve, and installed it. It still doesn't work. I replaced the flood switch, because it was obviously broken (thank gof we never had a flood!). It still doesn't work. I've tested the switches on the door, in spite of the unit always beeping on open/close, and they have continuity-not sure if I should do any resistance tests, or what my expected results would be.
What's next? I don't know what else to check.
