FrankF3
#1 Posted : Saturday, July 15, 2017 6:41:28 AM(UTC)
FrankF3
I have a GE JKP19G0K2 grange that is off in temperature when comparing the actual temp inside the oven to what the display reads. The unit uses a WB27X5417 control board that has a DIP switch on it. I've worked on other model GE ranges with different control boards that you could adjust the temp to get the actual temp to match the display on the unit. Does anyone have any info for the WB27X5417 control board and the operation of the DIP switch settings on it? The temperature is steady and solid just seems to run cold with respect to the display.
